f23 in a cb7?
    i believe they did that with a h23 head...
    Yeah but f22a4/6 would be less machine work and cheaper.
      I guess that would be all right if you were just going for the
      "oh well that is different" effect
      But my question...if you are really going for cheaper higher power...would the f23 block f 22 head make more power and/or torque than just the h22 by itself? Or the f23 with h22 head. Or does the h22 still do better?
      I personally would just use the h22...less hybridization, and that means it will be easier to do repairs and find parts...and easier to find help.
      wonder which would make more power though...I'm betting the h22 alone.
      ____
        The H22 would make more HP but the F23/F22 should make more TQ which is what I'm wanting. The F23 blocks also have a longer stroke(97mm) compared to the H22( i think, 90.7mm) which helps in this.
        If I was going to go H series I would go H23 due to the bigger bore and no vtec.
        I don't want or need vtec. I don't plan on running my motor past 6-6500.
        Also using the F22 head I will only need to buy 1 cam/cam gear not two.
        Finding a H23 motor for less or the same money for what I'd spend for whats listed above would be a challenge. IMO
        Not sure if I've gone too far off topic from the OP. If I have I apologize.
          I'm going to have to do some searching now on bisimoto...n/a power owequitit???
          ____
            I would have to agree w/ Dankspeed. I was also considering this b/c i want a motor w/ low mileage. Yeah the F22X is a good motor, but the mileage is going to be high...and i don't want to rebuild 1. I'm just looking for something as a daily driver.
            Vouches: Bruno8747, 1badwag, Excalibur02, Bliz07, Slick, Gloryaccordy, H23CB7.
              Go for it man,if u dont have between $800-$1000 on an h22. I'am going with a f22b1 since i cant afford an h22.
              NEW CB
              old Darkcloud : 1990 Accord EX MRT
              new
              DARKCLOUD : 90 ACCORD EX MRT
                What do i need to do this kind of head swap?
                Is it just like any ordinary head swap or is there something special i need to do or parts? I'm definately interested in doing it.
                  sorry to jump in but i have a question. my f22a6 blow and i have a f23 auto. will the f22 sitck transmission fit on the f23, also will the f22a ecu work or do i have to buy another one. and last which harness would be best to use in my cb7 the 94-97, 98-01. thanks
                    I was thinking about doing this swap once, f23 w/ the a6 topend, I think that way the cb harness would plug right in. Correct me if not.
                    1992 Accord Wagon (RETIRED)
                      the auto f23 accord (2000 model) pulls on a manual f22 93 accord...well my wifey and I were on a roll and she was ahead of me...by the time I realized what she was doing it was too late. I might have gained/kept up if I down shifted to 3 instead of 4...I'll see if I can get her to race me again to see how much of a difference her 15-20 hp does over me...*sigh...her car isn't THAT much heavier then mine my curb of 2733 vs her curb of 2948. I have f22a1 right now...might be pretty even.
                      sorry, back on topic
                      Honestly for the money, the h22 is a better bet. The f23 in my fiance's car is dohc and h22 is dohc, both have vtec...the f23 has larger displacement then the h22 yet the h22 still has more power.
                      Go with the h22...I believe you will be much happier
                      ____
