i just got my cb off a friend cheap cuz he was showing off and hit a curb at 45. it bent the lower control arm the steering knuckle and the sway bar. it also broke the front comression rod thing. i replaced the control arm and have been trying to get the knuckle off. the main problen is the axle nut. i cant get it loose and ive tried everything my mechanic said to do. if i woulda known it was gonna b such a pain i wouldnt have gotten the car but i need it for work. im open to suggestions.
steering knuckle removal
to get the axle nut off, i kno the nut rotates with the axle i kno its kinda a long shot, but ive seen it done before, but its kind of a long shot, it was on a totally different car. put the wrench with the pipe extension on, jack the car high enuff 2 hold but low enough so the pipe reaches the ground and i beleve u put the car in reverse, slowly shutter it off, not too fast tho because if it doesnt come off, your car is gonna fly off the jack. break the nut rite off with the axle.1990 Accord EX Sold
1995 Accord LX V6 Stored
1999 Accord LX Daily Driver
Chances are you're not doing anything wrong but that its really just stuck. It's probably been there for a long time. I had the same problem and I broke my breaker bar in the process too. Spray pb all over inside the nut. Let is soak for a good one. Use the stock rims as you can have the wheel on the ground when you try to loosen it. Use a good breaker bar and maybe even an extension pipe. If all else fails, you'll have to use an impact gun with enough psi behind it to bust that shit off.
...adjust accordingly
Find somebody with a 1" impact wrench...the kind they use for 18-wheelers. I promise something will come loose if you have enough psi and air flow behind it.My Member's Ride Thread
i got it apart now. it took a 3/4 inch breaker bar and bout an 8 foot pipe. i had to have my brother on the end of the pipe cuz im too light. i got the nut off and everything is apart. soon enought ill b able to drive it. its not gonna b put to work anymore cuz i bought a lil truck off a friend for $500.
specs: 17" rims and stock everthing else
