F22B2 in 91 LX
    F22B2 in 91 LX
    does anyone know if a 97 F22B2 SOHC nonvtec engine and tranny (Auto) work in a 91 LX. I can buy this engine and tranny pretty cheap and need a motor and tranny for my accord. Will this work, what do I have to change. Anyone know for sure. Im not looking for any performance just want something to drive. Thanx
    Mr. $3 Dollahz Himself!
    bump for the man somebody help him out i'm not sure on this swap
    93 SE sedan aka Green Lantern sold 3/14/05
    93 10th Anni. sedan sold 10/16/06
    92 Toyota Std Cab 4x4 sold 11/10/07
    92 H23 Coupe 100 shot
    94 LX Wagon
    00 Odyssey LX
    92 LX Wagon
    87 Toyota Ext Cab 4x4
    H/FSAE (H/F Series Accord Enthusiasts)"A dying breed..."#19
      I'm pretty sure it will drop in physically, but you're gonna have to swap your ecu and tcm to obd2 or revert the new engine back to your obd1, which I'm not sure is possible.
      My Member's Ride Thread
        You're right. And it's possible. There are harnesses availible to revert to OBD1. I believe an OBD1 F22B2 ECU would be needed for this.
        Installation is about as involved as with an H22. However, the F22B2 is a really crap engine. The F22A is a much better design.
        edit: I was thinking F22B1... F22B2 is still a crap engine
          Depends on what year f22b2 they started them in 94-97 lx and crap. Yea it should fit its almost like the F but the header and I think Intake Manifold have different port patterns. If you could just stay with the f22a. Head flows better and not much modification required. How much are you gettin this f22b2 for if you dont mind me asking.
            free
            I got the engine for free. Its an auto, can i change the flywheel assembly to make it work with my 5 spd. tranny. I just need my car to run thats all. has anyone done this if u dont mind pm me or something. the engine will be here 2morrow.
              The F22A 5 speed transmission should bolt up with no problems. For free, it's a good engine. If your car needs a motor, it's good. If your F22A is in good working condition, then there's no need. It's no better, probably worse.
                my f22a4 is dead
                my F22a4 doesnt run, timing belt broke and Im pretty sure now that it has bent valves. Does anyone know exactly what mods have to be done to make the 97 f22b2 sohc(non-vtec) work. and can I switch the flywheel assembly?
                  flywheel should be the same size as f22a. And the rest is just an obd2-1 conversion. Also you would need an obd1 ecu.
