I was driving home today and i couldnt go over 50/60 mph. Then in every gear when i pressed the gas, no power as if i wasnt stepping on it. No rpm or nothing. If i pumped the gas pedal it seemed to pick up a little but not much. Damn i barely made it home.
Im loosing power.....WTF?
Check to see if you have a restricition in your exhaust. I've seen this be a problem before in not letting the car go past a certain mphJDM H22A LSD Powered 92 Accord
193.9 HP, 149.5 TQ
Skunk2 Pro Intake Manifold, Custom Header with 2.5in. mandrel bent exhuast
Accuracy Automotive-757-548-9227
Originally posted by CockyJust had one about 500 miles ago. New distributor cap wires etc. I usually get white smoke on start up. Could that be the problem?
I can cover my tail pipe with my hands and my motor will still run like nothings wrong. funny thing is that I can only see one tiny hole in it. alot of backpressure will kill the power of a motor. before I hit up a exaust shop after my swap, My down pipe was messed up and restricted it quite a bit, it felt pretty gutless, but there was still alot of air going through the exaust.spin city
