For all those with idle problems
    This worked wonders my car no longer idles rough
    Thanks
      For the record..my car idled/reved by itself up from 1000 to like 2500 on its own..it was my radiator..it had no fluid, it was coroded..so that could be a possibility for some.
      1990 Accord EX 91200 miles..SOLD 2700$
      out of the game for now but looking
        Doing what was suggested helped my idle problem, but it wont hurt to get my rad checked out
          um...so after i tightened it it seemed great..but it was while the car was warm.
          the other day i started it and it was kinda cold ya know and it didnt like warm up. you know how it usually revs to like 1500 - 2000 to warm up. well mine was like like 900 and when i shifted it to R it dropped even more like almost dead lol.... so um i guess im asking if i need to replace it or if its something else.
          Accord SE
          93se
          Members Ride
            bump
            Accord SE
            93se
            Members Ride
              Pictures doesn't work just red x
                A thread I made after repeated issues
                http://www.cb7tuner.com/vbb/showthread.php?p=1221752
                if you have any more questions ask away!
                ____
                  this doesnt help me
                  ok so i have done everything and anything that the books and this thread has said and my car with the IACV plugged in idles at 4k rpms with it unpluged idles at 1900-2100 surging
                  heres whati have done
                  1 engine replacement f22a1-f22a4
                  2 trpile checked everything
                  3 adjusted the idle screw all the way tight
                  4 tightened the FICV
                  5 cleaned the IACV
                  6 reset the ecu for adjustments
                  but still rev high and never goes down plus my fan doesnt ever come on i have removed the a/c i have no idea please help
                  "accidents in the back seats cause kids"
                  but who says that i
                  have back seats in my sedan
                  THE ALASKA EXPERIMENT
                    5 cleaned the IACV
                    you have an intake leak...check your gaskets and vacuum lines
                    ____
                      after i adjusted it the next day it was kinda cold out and when i did it it didnt have the norm warm up rev.. and when i shifted it to reverse it like almost died and was idle at like 200? what can this mean?
                      Accord SE
                      93se
                      Members Ride
                        either you set it too low or your fitv needs adjusting...try keeping your idle around 700-900...not "spec" but works fine for me
                        ____
                          When I start my car it goes to 2rpm maybe some times a little higher and when it warms up it goes to a little over 1rpm and it starts jumping back and forth from 1500rpm to 2500rpm and I tried all those things what can it be? thanks for your help.
                          92 Accord Cb7 ^^
                          My Ride Thread~~Click Below.
                          http://www.cb7tuner.com/vbb/showthread.php?t=176232
                            screw could be backing out...
                            could be a vacuum leak
                            ____
                              Ook I tried everything today again and it idle fine but when you go to start it, it starts as if it has no power and then it goes back to normal.
                              92 Accord Cb7 ^^
                                haha i actually just did this 5 mins ago after reading this.. worked like a charm.... my idle was off cause i dropped a new motor in but used my old intake.. so had to adjust it
                                You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
                                Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
