For all those with idle problems
    Thank god for this thread. Ive been pissed off at my car for the whole day. I took out the butterflies from the iab plate and i threw on a 65mm bored tb. And the upper plenum off my dohc f20a. And it ran like complete shit. (still is) Tomorow i will be doing all that has been done by you guys. Is this thread a sticky yet or what?
    My New Ride
    http://www.cb7tuner.com/vbb/showthread.php?t=82630
      Originally posted by arctichonda View Post
      Whoa, whoa, whoa.....that valve is expensive and before anyone goes out to buy a new valve try to tighten it first. Open up the top of the valve and put a screwdriver into one of the cuts on either side of the valve and turn it clockwise in order to see if its loose. It should be tight. I used two screwdrivers- one in each cut and turned them both at the same time.
      this helped!!! i have no more idle problems!! woot woot!!
      cb7 rebuild coming soon!
        Does anyone have the picture of the IM that was used by the OP? It's not up there anymore and I need it to fix my problem. Thanks.
          thanks
          well i did what you said and bam there it is fix my problem
            i had/have this problem with my idle. it idle at 200 sometimes less. then i sent it to my mechanic to do work on the engine. he sugested to raise my idle i said OK. so then he raised it and it was around 800 and then it would raise and fall again. this lasted for like a month. now my idle its back where it started. it doesnt bother me at all. but is there seriously something wrong with my car?? PIC BELOW!
              did you read the thread and try all the items mentioned?
              More than likey though sounds like a bad IACV...as the FITV I believe is responsible for cold starts and IACV is responsible for warmed up running.
              ____
                when you say delayed start, as in you hit the key and it wont start right off, takes a second key turn? mine has been doing that alot lately..
                  my car is surging like crazy im going to try turning those screws u guys are talkin about, still some pix would be nice, not those red "x"s
                    so have you found a fix fopr this yet or at least a reason for this cuz my cb7 is doin the same and has actualy stalled out on the road when coming to a stop. when in neutral it idles right around 100 200 rpms
                    but it seems like the engine was stil somewhat running just super uber slow cuz i just turned the key for not even a half a sec and it started right back up
                    it didnt seem to even have to turn over
                    92 LX N/A rust bucket restoration RIP
                    91 DX Coupe to 9293 EX Coupe restoration
                    funds for swap:$000.00
                    Bought from:HondaFan81=My current CB7 DD ,CB7_Sleeper1 Koochologist Tommi mtnbikkerkid33
                    Traded with: Wed3k
                      did you adjust your idle via idle screw?
                      ____
                        cleaned out the IACV, instantly perfect.
                          My crap has a rough idle and when I turn the lights on it gets worse, maybe its the alternator?
                            I checked the fast idle valve and its tight, this morning it did the weirdest thing, turned it on and it idled up then down and turned off. It did it 4 times then it stablized like normal. I think im gonna clean out the throttle body and see if that works
                              THANK YOU!!!! that idle was annoying as hell
                              1992 Honda Accord Lx
                              [/I][/I][/I]
                                how would i go about adjusting the fitv if i have bypassed the coolant lines on it? i have a h22a btw. im not gonna go talking about how my idle is surging cause thats been covered a million times and then some.
