I just diagnosed my car and i get code 7. This is the tps or throttle position sensor. Anyone know what this si where its located and how to fix it?
tps? throttle position sensor?
If you need a new one if I remember its riveted on so you will need a drill to drill them out. Then replace them with normal bolts. Setting the TPS is in the DIY section.
Originally posted by NAiL05If you need a new one if I remember its riveted on so you will need a drill to drill them out. Then replace them with normal bolts. Setting the TPS is in the DIY section.
