h22a VTec
    h22a VTec
    Vtec works 2 times then stops
    there are no codes in the memory
    and the motor is full of oil and
    there are no dents in the oil pan
    and cleaned the filter.
    ? is there a way to jump the vtec pressure
    switch so it will read 0 volts or whatever
    so vtec will work for testing only
    cause i did the vtec solenoid
    already it is fine.
    need to test the pressure switch.
    can i use a 10k resistor or what
    ever
    NO matter how many times we downshift vtec is on our side.
    which ECU are you using? have you tried a different ECU to see if the problem still comes up?
      yeah bro what ecu are you using?
        p13 ecu
        and a p28 chipped
        but using the p13 till i get the problem fixed
