problems with a/c
    problems with a/c
    Hey guyz i need some serious help.
    1) Why is it that when i try to recharge my a/c the gauge reads like 80 which is the "danger" zone BUt theres like nothing in it, because when i press the valve down for like 4sec its like its empty.
    2) When i press the a/c button the fans dont go on, im not sure if thats a problem but i picked up a 93 se and the fans go on in that one.
    3) can i just swap out every thing (a/c) from a 93 se 2dr accord and put it into a 92 ex?? I was just wondering because by just looking at it, the setups look a lil diferent.
    I am a noob at a/c but I need some help so all input will be appreciated.
    wtf i dont get it, man my car does this too, and its a bitch now that is winter, wish i could help you man but at least you now know that your not the only one with this prob or wait for a bad a/c
    lisa is long gone, but sophie is here!
    i got a good feeling about this one
    im going to have to
    __________________________
    |...OVERNIGHT PART'S 4RM....||'|";,__
    |..............JAPAN.................|| ---**-)
    |_..._...____________======||_|_|__--]
    check out my mr thread
    http://www.cb7tuner.com/vbb/showthread.php?t=106541
      ill post up tonight what i know, im in school now and dont got much time.
      miss my turbo cb7
        Check your charge hose and see that it is pushing in the valve, sometimes the hose is on backwards and you are reading can pressure instead of system pressure. You will need to suck down the system with a vaccum pump before you charge it as air does not compress well and you need to pull a vaccum to get all the moisture out before you charge it. Also if there is a problem with the system and the compressor is not coming on you will not be able to charge it without a charging station to push in the freon.
        The 90 Accord 4DR Sedan my son and I are building.
          1. Might be stupid but did you drain the gauge before putting it on
          2. Fans are supposed to comeon when A/C is engaged and if it aint pulling air through could be hindering the cooling of the condensor/radiator.
          3. Should be able to swap em out I would think they are the same.
            what do you mean drain the gauge?? how do i do that??
              theres a valve in the front by the radiator
