which ECU is better to run f22b1 vtec?
    I am installing the f22b1 this weekend and I wanted to know which ecu is better to run it? p06, p28, p07?
    whats the difference in each one?
    after I get the ecu how do I wire up the vtec?
    need help badly
    p28. But it needs to be chipped and use a basemap. Or you could use the stock '94 or '95 accord EX ecu. You would hook the harness up just like your old motor then make a harness from the VTEC switch to the ECU.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      ok so if I go with the p28 where could I get the chip and whats the basemap?
      how do I know which wires go where?
      Thanks for the tips I really appreciate it I want my car on the road so I can goto the jersey meet.
      what is the code for the stock 94 95 accord ex ecu?
        the code for the stock 94-97 VTEC ecu are POA
        yes, u can use the p28(or a p06) but requires u to chip it, to learn what chipping envolves, go to the performance section and read up on MRX stuff
        basically chipping is taking a "chippable" ecu, creating a basemap for which the car can run of its fuel and igntion maps w/o any knocking, pinging, or hesitation problems, although a basemap is purely what it means...BASE...it wont be perfect, you'll have to iron out the areas to get the most outta of it
        "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
        I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
          p06 needs to be converted to a p28 to be able to run it. Normal p06 is for non vtec motors.
            okay i got
            so how do I know which wires go where for the vtec?
