i have a question about alignments, when you take you car to get an alignment done do they actually adjust whatever has to be adjusted or do they tell you that you have to replace certain parts before you they do it?
Alignment
They will adjust to the tolerances. IF they see something that needs to be fixed they should write it up in your receipt or they will ask you on the spot if you want to go ahead and replace it.
most places will inspect your car first, suchs as ball joints tie rods, bushings and thing like that to make sure they do not have play in them, if they find anything, they will tell you to replace it first or they won't give you the warranty, once they align it, they will try to get the readings to manufacture's specs
