does anyone know?????
    I am getting a f22b1 vtec engine and I want to put it in my 90 accord. Will it fit?
    How do I put on the vtec?
    This is the picture of it. F22b1 vtec
    Do I need to change my ECU to use vtec?
    yes it will fit, might as well not wire up the vtec, u wont feel it. it is used in that engine to help with gas milage if i remember correctly
      im pretty sure he wants to wire up vtec since im assuming thats why he bought it. just because its not the same VTEC system as the H22, doesnt mean its not beneficial to wire up.either way yes the F22b will fit. the exhaust manifold doesnt bolt right up to the catalytic converter if i remember right. and a couple ecu pins are gonna have to be switched around depending on which ecu you get or have.
      also i believe there is a minor issues with the fuel rail/fitting. the info IS on this site. a little it of browsing and you will have all the answers you need.
      good luck!
      Sean
      F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
      Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
      Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
        good luck!
        Sean
        okay I am going to use my ecu f22a4. How do I link the wires to it?
