SeaFoam and Hydrolocking
    Ok, Ive searched, and read I think every post about sea foam on this site and Im still looking for answers.
    oK, so sea foam is a liquid, and to use it you suck 1/3 of a bottle slowly into the brake booster line with the engine running. Here is where the the opinions differ. Do you
    a. overload the booster line with sea foam tell it dies.
    or
    b. load it tell it idles down to near stall and shut it off.
    After both your suposted to let it sit anywhere from 5 to 15 mins before attempting to restart.
    I keep seeing the first come up over and over. Isnt this basicly hydrolocking your engine? I thought sea foam was combustable and there is alot more air comming in the intake than there is comming in the brake booster so wouldnt you need ALOT of sea foam to kill the engine... roughly the amount needed to hydrolock?
    Im not trying to spread rumers about sea foam, it sounds like a worth while treatment but im not in the mood to replace rods and valves anytime this year.
    Another concern is im running about 163,000 miles on my motor. Good Idea or bad idea to use this stuff. Any ways to limit the exposure to my gaskets and seals? (oil change after the stuff is burnt off?). Thanks.
    I cant Slam further. The ground refuses to get any lower.
    when i do it i pour it in slowly through the brake booster line with a funnel while keeping the revs slighly up so the car wont die.....when i have done about 1/3 bottle i then shut it off it might run for a few seconds after shut off....i let it sit for like 10-15mins and then start er back up and drive it till it stops smoking.i have jsut about 130,000 miles on my car and have perfromed it atleast 4or5 times with no problems .....i have had no problems
    My Members Ride Thread
      what is this "sea foam" treatment supposed to do?
      D-series.org
        read this for detailed info
        helps clean out the engine
          it's suppose to clean the carbon deposits within the engine.
