luke warm heat
    luke warm heat
    Hiyas im new to these boards and i have a few questions...my heater just blows luke warm air...maybe heater core and i dont want to mess with that yet and its not blowing hard at all it blows like its on low when i have it set on high..my blower motor is fine cuz i can hear it turning on and blowing real good....could something be blocking the air flow?
    1st welcome to the board.. try searching im almost positive this has been covered before!!
    .............................-----------------93 Ex Coupe[/COLOR]-----------------
    My CD7
      flush the heater core....then clean the air intake grill above the passengers feet in the foot well and third SHEARCH
      R.I.P. 6-10-07
      (\__/)
      (O.o )
      My Rotor DIY
      I'm not perfect i will make mistakes if i do just point it out to me
        thanks for the responces but where is the air intake grill..is it by the blower motor box?
              welcome Papeon,
              i don't think your heater core is to blame. ususally the heater core leaks when it goes bad.
              it could be anything from your thermostat being stuck fully open to the climate control cable getting loose to the climate control unit itself being bad.
              it is unlikely that there is some sort of blockage as there is no cabin filter in the cb.
              and the answer to your question about the location of the air inlet for the HVAC, it's the black plastic piece below the windsheild were the wipers are.. it gets cloged with leaves at times. later.
              Avoiding dirt at all costs
                Have you checked the coolant level? When its low, the heat goes down...
                  are you hearing the fan change at all speeds? also, does your vent control move the airflow around the different settings easily? just thought it might be binding and not letting the full heat pass thru tothe cabin. just my $.02
                  If you're gonna go, go with a smile!
                  Current vehicles: 2006 Pacifica Touring Inferno Red (the Wife's) - 30k
                  1993 Accord EX - optima 'red top' battery, magnaflow exhaust, tinted windows - My $500 ride w/ 217k miles
                  2004 Suzuki GSXR750 - Racetech sus f/r. Dunlop Qualifiers. clear Puig DB screen. my drug - 7500 miles
                    yeah ive check the fluid and it was fine...the heater valve on the firewall was a little tight but i lubed it up and its moving more freely now...i can hear the fan on all speeds and i can hear a clicking noise when i change to diff types of vents...wonder if something is not openeing up all the way and not letting the air through...maybe its just me but isnt it suppose to be blowing hard when its on high?..if a thermostat was going bad..wouldnt the car be overheating?
                      yeah i thin it might be my heater core now...the inlet hose was warm to touch but the outlet one wasent really....are these easy to flush out?
