Ok after idleing for like ten minutes the temp gaugegoes 3/4's the way up and after like five more minutes the car is almost in the red zone I noticed my fans do not come on until i turn the car off the coolent is 50/50 and filled to the proper levels and the thermostat was just replaced just want to know why my fansonly come on when the car is off I tried turning on the a/c and the fan still does not turn on. Thanks
Overheating fans?
what color is your coolant when you take the radiator cap off when the car is cooled? just because you changed your thermostat doesnt mean it could be faulty just a thought. Also are you shooting any codes i remember when my thermoswitch thats screwed into the head of the block just below the distributor it would give false readings and cause the fans not to operate. pray its not your headgasket or waterpump
the coolent is a good color no oil or anything no codes no check engine light just the fans do not come on only when the car is off do i need to replace oe of those two coolent sensors or the fan timer or relay or somthing i dont think it is my headgasket or water pump both radiator hoses are the temp to the touch and the same stiffness
When you turn on the AC which fans turn on? Do none of them turn on? Could be a bad fan switch. IF one turns on at least with the AC on then the other thats not working needs the motor replaced. But I would make sure all your connections are connected but I would check the fan switch prob no good.
Check the fan switch then prob sending the wrong signal or its jsut broke.
I think its located on the front radiator neck in the front of the car. if I remember its one of those I know its not on the t-stat housing. The parts store should be able to tell you. Havent replaced mine in a while.
if you or someone you know has a multimeter, check the switch for continuity, if there isn't any in the switch, then it has an open : / ie:bad switch(\__/)
(O.o )
1991 Accord Ex Coupe:
-RAI, New(ish) cylinder head, high power alternator (wtf )
-Exhaust tip
-DIY PCV Filter
-DIY Oem Taillights
Umm, yeah, my car needs some T L C
People I've Purchased From: Kmart64,Yeamans17, (yournamehere )
