Fuel Pressure Regulator to lean out my mixture?
    Ok, since I'm STILL having the troubles with the EGR and it's causing my car to run super rich, if I get a fuel pressure regulator would I be able to use that to lean out my mixture? Just curious.
    I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
    "Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
    CB7: The Movie TEASER VIDEO
    fix/replace the EGR would be good or chip it to where the EGr isn't reconized
    1990 Accord EX -Stock to no beyond
    Originally posted by yeamans17
    you'd better soak the nuts in pb blaster, otherwise you'll snap them off
    "Be who you are and say what you feel, because those who matter don't mind, and those that mind, don't matter" - Dr.Susses
    Vouch - | gloryaccordy | aznkid.com |
      both of which cost much more money than a simple autozone FPR which I'm trying to figure out if it would lean my mixture, at least in the meantime.
        IMO if your gonna fix it fix it right. No point in half assing it because your just gonna ask for it to break later on. But that is my opinion though. Yes you might be low on funds but its better to do it right rather than buy a part and still not fix it. Plus playing around with the Fuel pressure can risk blowing your motor and such. Did you ever find out which wires were which for the EGR? and test the voltages on them?
          Ok, let's just go with "hypothetical" now and I will try the question one more time.
          Can you use a Fuel Pressure Regulator to lean out your mixture? Look I know it's the wrong way....but at this point I'm just curious and wanting an answer to my question.
            YEs.
              Y.E.S but at bear minimun get a o2 gauge.
              Not my fault my dick only fits magnums.
              Why drink and drive when you can smoke and FLY?
