S2000 motor?
    S2000 motor?
    Could i swap a S2000 motor into the cb7? I think they have about 240Hp? how much do you think labor would cost, wouldnt trust myself to do it.
    probably... but they are Rwd...
    Upgrade your mind before you upgrade your car
    "So. Cal OUTLAWZ "
      it's not going to be easy/cheap, but i think it can be done, i've seen them on civics RWD and damn!! they pull very hard. Lots of custom work must be done.
      Go with a H22 easier and cheaper
      Big 16g Turbo/H23 Head Swap/TSX Projectors
        Ok never mind since its rwd, but which is a better engine, H22, or F22b, F20b? Or atleast... which would cost the least with a decent amount of power
          haha now i know that it will fit i will start doing some redesigns on lovely Catia to see if i can mod the underbody enough to fit a tranny and drive shaft and all the other lovely things that come with RWD. this wont be for a while till i get the funds to do it though haha.
          1990 Accord EX -Stock to no beyond
          Originally posted by yeamans17
          you'd better soak the nuts in pb blaster, otherwise you'll snap them off
          "Be who you are and say what you feel, because those who matter don't mind, and those that mind, don't matter" - Dr.Susses
          Vouch - | gloryaccordy | aznkid.com |
            Buy an S2000. They're cheap enough now, you can get an model year 2000 for ~ $12-14,000.
            After 17 years and 208K miles, I'm not "tuning" my CB7, I'm "restoring" a CLASSIC.
              Read the swaps section!!!
                you have to remember that the 240hp is not to the wheel. plus rwd cars loose a bit more thru the drivetrain than fwd. but if your like most, you'd just do the most pratical swap that you an do.
                91 Ex CB9
                JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
                W.I.P.
                p72 ecu on Hondata
                To Come
                Weight Reductions
                R33 or R34 front end
                  no you can't swap the eng. it spins in the opposite direction of f,h engines
                  just get a jdm type-s h22.......220 stock and it comes with a lsd tranny
                    How does spinning in a different direction matter though. All that owuld be is a difference in circular motion... you could fix that through the rear dif or just do a resign and such on parts to get the right circular motion of which you reffer to....
                      i dunno man, but it keeps me up at night
                        As he mentioned. The only bad part about the s2k motor is that its rwd and you would have to find a trans that will adapt to it unless you want to convert to rwd. If spinnin the other direction mattered how are people throwing K series motors in tehre civics and such? So it is possible and which way the motor spins really doesnt matter.
                          220? maby for the type S
                          and at the crank
                          at the wheels an h22a only makes 170-180 whp
                          Old Ride-New Ride
                            and at the crank
                              i mean yeah if he wants a rear drive accord, then he could use the eng and tranny. alot of ppl see f22 0r f20 and think you can just bolt the eng into an accord...and it ain't happen
