F22a1 turbo setup questions
    I am kinda new to this, So if anyone could help me out it would be much appreciated.
    Ok, My brother will be installing my turbo setup sometime in the near future, And I have all the turbo components( turbo,intercooler,manifold, piping, oil lines,ect.) I am planning on running 8psi wich is what the internal waste gate on the turbo is set at. Is it a big deal if I leave the stock injectors, or do I need larger? Also I need some feedback as far as getting a chipped ecu for an f22a1 and what will happen if i use the stock ecu?
    Any feedback will be greatly appreciated...
    stock injectors- you will run lean under boost and your motors goes boom
    stock ecu- see stock injectors
    you need a chipped ecu or safc or fmu. you also need bigger injectors
    Shift_BOOST
    BOOM!
      most people upgrade to the 450cc dsm injectors, and usually a fuel system upgrade is recommended. also, its best to get a chipped p06 and to then get it tuned somewhere reputable, as if you do not, then bad things have been known to happen.
        DSM is probably the cheapest route.
          lol
            what downpipe would we use for a turbo f22?
            Myspace
            My ride
            my vouches
            H22 fund: $125
            My rides:
            92 civic B16 (sold)
            93 civic B18A (sold)
            93 accord F22A6
            91 civic 4 door (sold)
            98 GSXR 750 traded for B16 swap civic
              Thats cool, I can get the dsm 440cc injectors for almost nothing, and I can get my hands on the p06 at the local junk yard, But as to getting it chipped does anyone recommend anywhere to get my hands on a chip that will support my setup? I just want to get everything ready for when he comes up here to NY from Oklahoma city. He will only be here for about 5 days so I want everything I will need.
              Thanks for the help
                speak with mrx...he does chipped ecu's...hes done ecu's for some mebers here f22 turbo setups
                My Members Ride Thread
