I have a coolant leak from the rear of the engine.....and its not dripping...i would pour coolant in the rad and it would just leak out....
I couldnt exactly see where its coming from so i jacked the car up and removed the driver side front wheel to gain more access. So i went under with a light and looked, but didnt see anything. All i can see is that its running down the block and dripping down to the floor........
the only place i suspect but I DONT KNOW AT ALL........is that there is a piece of pipe that goes across the block.....its black and its in line with the engine, there is a hose connected to it and that hose runs to the firewall......so i dunt have a clue
i can only see it leaking out, but from where, i dont have a damn clue
And everything was fine, thermostat was good the coolant was good.....everything was a ok......
any1 know where the leak is coming from....its sad to say but i think the engine is gone....
PLZ HELP.......any11111
