Intake Mainifold
    Intake Mainifold
    i finnaly opened the hood to try to fix my idle problem, i took the front valves off of the intake manifold and cleaned all of them, but there was still no change in my idle. i took the whole inake manifold off to see if there was anything i could clean behind it and the inside of the maniflod was dirty as hell so i cleaned it, but the intake manifold is off of a Ex accord and when i first put it on my car, i cleaned it real good, i guess this means i need a new cone filter, or can it be something else? and also i search all over but what else could my idle problem be?
    My Myspace
    91 accord lx 4 door 5 speed (a.k.a grasshopper)
    Mods:
    -Short Ram intake
    -92 accord EX intake manifold & exhaust
    -Ebay coilovers
    -BMW M3 style mirrors
    -OBXr Evo style exhaust
    -Multi-Colored Paint Job
    -cheap-o rims
    im goin to UTI June 17 2007
    First thing that popped up into my head was the IAC valve, I know you say that you cleaned all the valves but go ahead and check this out in case you missed something,
    http://www.cb7tuner.com/vbb/showthread.php?t=53161
    1992 Honda Accord Coupe LX
      COuld it be spark plugs and such? wiring, not strong enough sprk maybe? possible carbob built up on EGR? waiitt yea i dunno about the EGR becuase i can'
      t rm if its used in idle, i dun think it is maybe? someone could confirm or deny my sayings? theres my $0.02 cheers
      1990 Accord EX -Stock to no beyond
      Originally posted by yeamans17
      you'd better soak the nuts in pb blaster, otherwise you'll snap them off
      "Be who you are and say what you feel, because those who matter don't mind, and those that mind, don't matter" - Dr.Susses
      Vouch - | gloryaccordy | aznkid.com |
        im doing alot of things to make my car run better in this paycheck, ill see how it goes after that
        My Myspace
        Mods:
        -Short Ram intake
        -Ebay coilovers
        -cheap-o rims
          Did you clean and adjust the FITV? Check all vacuum connections. Even the smallest unplugged hole cause eratic idle. Check the coolant level and also the radiator cap. A worn cap causes bad idle as well.
          ...adjust accordingly
            Sometimes cleaning the IAC doesnt help. Sometimes you just need to buy a new unit. And it wouldnt be a bad idea to adjust the FITV while your there.
              Wheres the FITV located, and how do i adjust it?my cap is worn, im going to get a new one, also, the coolant is a nasty orange color, i should probably do a rad. flush this weekend
              My Myspace
              Mods:
              -Short Ram intake
              -Ebay coilovers
              -cheap-o rims
                change your pcv valve.
                it's been a while but i'm back!!
                  Standing in front of the engine the FITV should be located toward the right side of the intake manifold. All it takes is a phillips head screw driver to move the steel piece adn you will see the adjustment inside. Try to get something thick enough turn it clockwise until it goes down all the way. There are two phillips head screws forgot to mention that. Plus i think its the next valve looking thing next to the IACV to the right.
                    I would pull off your egr valve and clean it out really good, check for vacum leaks.
                    but can you clarify what your idle problem is? is it rough? does it surge?
                      Check the link I posted above, it has pics and description and is very easy to follow.
                        it surges up to 3000 rpm, it gets a little higher when i hit the brakes
                        My Myspace
                        Mods:
                        -Short Ram intake
                        -Ebay coilovers
                        -cheap-o rims
                          well then its either you have a really big vacum leak...or the adjuster screw came loose on your fast idle valve...does it surge at all? if so then you might need a new IACV (idle air control valve)
                            is there any wuick way i can check for vaccum leaks?
                            My Myspace
                            Mods:
                            -Short Ram intake
                            -Ebay coilovers
                            -cheap-o rims
                              thanks, i had looked at that before, but when i decided to work on my idle, i couldnt find it
                              My Myspace
                              Mods:
                              -Short Ram intake
                              -Ebay coilovers
                              -cheap-o rims
