mis @ WOT
    mis @ WOT
    so cleaned out my iac and now when i give the car gas, not always wot but even on acceleration the thing misfires. did all my ecu resets and wat not.
    and the wierd thing is sometime it works fine no mis help!!!
    so its a random misfire? did u pull out the 7.5 back up fuse to reset the ecu?
    Members Ride
      yeah even dis-conected batery to make sure!!!
        Ehh hows your basic tune up. Plugs wires and all that good stuff.
          all within 15k
            so did the cap, rotor, plugs, and wires and even adjusted idle.still have the mis. not getn a cel or a code out of the ecu. can any1 help!!!!
              any vacuum leaks? any over revs? bent valves? do a cylinder leakage test, or take it to the mechanic and have them do the test?
              Members Ride
                how hard is the leakdown test?? can get a tester at harbor freight 4 like $50.and y would the problem start after i cleaned the iac.
                No over revs, no vac leaks, was fine until cleaned out the valve.
                  fuel filter?
                  91 lx h22 ftw!!!1!!one!!
                  lsd is wonderful
