trany problem
    trany problem
    i got a 90 lx auto... and it just started acting up. for a few day it would not shift into third or fourth untill i went through the gears and made it.. and last night it wouldnt go into any gear... i turned the car off for a few seconds and then it went back into gear... later it died again and i left it... my friend moved it later but he said i would only go in second... im thinkin the tranz is shot.... help me out here...
    that sounds like an electrical problem.
    when my transmission started acting up, I swaped to a manual.
    spin city
      i just put a atcu in it.. but it was from a junk yard.... but i want to put a man. in it... what should i do about the clutch and lines? get aftermarket or oem?
        I used oem. it only took about 15 min to get em into place.
        spin city
          Are your lights flashing? D4/S light if you have one? If you do jump the TCU for codes.
            check trouble codes. you may need a new auto trans computer. if not then it may be your shifter solenoid
              i got no codes... i just put a new atcu in it like 3 weeks ago..
                have u checked ur tranny fluid? when was the last time u changed it?
                thanx for da sig. DFRHonda
