winter tires , what sizes can i use ??
    Can i put p155/70/r14 winter tires on my 92 honda accord lx car ?
    I can by tires at p155 ? or p185 ? whats the difference ?
    What kind of tire size can i put on for winter ? I want p155 is it possible ?
    http://en.wikipedia.org/wiki/Tire_code
    educate yourself.
      I guess i am going with p185/75/r14 wintertrac tires and getting them studded for icy conditions.
      thank for the info, love wiki. wintertrac w/studs sound good for my honda, it legal here in sault ste marie, ontario canada.
        get 195's....
          p195 it is......
            Generally you want a thinner tire in winter.
              yep. so the tire will sort of sink into the snow and get better grip rather then be wide and just float over the snow
                185/75 is the stock size for the 14" wheel. It's probably also the best size for a winter tire.
                195's aren't going to be right for a 14" tire, nor will it be beneficial in the snow. The only way I'd go thinner than a 185 is if you did a 175/85-13 on 13" wheels, but I think you'd have a hell of a time trying to find 13" steel wheels with a bolt pattern of 4x114.3. I know my mom's Escort had 175/85-13's stock.
                  Thats good advice. I know when I first got my summer tires I also bought a set of winter steelies and made the mistake of thinking wider is better. WRONG. That may be true for summer driving but its the exact oppisite in the winter. Later
                    SO what do i get 195's or 185's for winter ?
                    I guess 185 are thinner and better for snow? Can i use 155's ?
                      Probably 185's would be your best bet. Dont want to go too thin. I would think it would be best to stick as close as possible to the manufacturers suggested tire size. Later
                        Sound good,
                        i found this in the mean time
                        http://forums.torontoaccords.com/vie...t=winter+tires
                          I am using Dunlop 195/65-15 .And the weather here in Norway can be a bitch.
                            Please learn about the tire numbers.
                              I just put on what ever the size said on the placard.
