car jerks constantly, brakes n stop, idling is messed up
    pls help me out here
    i drive a 90 accord, manual transmission, carbuerrator
    the problem is that the car jerks when it is moving and i mean serious jerking
    plus the car would go off whenever i hit the brakes,
    and the idling is also bad. am at a total loss here cause all the
    repair shops i have gone don't know what to do all they do is clean the
    carbuerrator and it still does the same old thing. HELP OUT PLS
    Somebody answer his question cuz I have somehow the same problem. Whenever I hit the brake and the speed drops below 30M/h; the engine stalls really bad and eventually dies whether my foot is on the clucth or I'm in neutral or both. Notice that my car has a DIRECT INJECTION. What could that be?
    Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
      Maybe need to rebuild the carb? Need to adjust it? You make sure engine mounts and such are ok. Not really sure abot the carbureted engines since we dont get those here but I would give those a look.
        rotors are gone if u brake and the steering wheel shakes...
          when you say jerks...like bad alignment jerk? and go off...like stop running? or pull to one side or something?
          Lois: Oh, I haven't been on a college campus in years. Everything seems so different.
          Stewie: Really? Perhaps if you laid on your back with your ankles behind your ears that would ring a few bells.
            The motor mounts can cause serious vibrating? My 93 ex is vibrating something fierce.
            she is down....but definately not out
              solved the brake problem and the jerking
              the jerking was being caused by bad fuel supply from my fuel pump
              i guess something was blocking the pipe that draws fuel to the pump ( i use an
              external pump ); and the brake problem was being caused by a lost screw that was supposed to block one of the air holes in the carburretor
              and since i locked the hole in the carburretor it stoped going off,
              my dash board vibrates when i get up to 90 kmph but that is because of my stabilizing linkage, and my wheel balancing which i need t o fix so thankx guys
                try playing with your icv...
