when i put my car in gear everything shakes and my idle goes way down like the car is going to die..i checked all my motor mounts and they look fine..the wierd thing is once i drive the car for about 15 minutes or so the shaking goes away please help with any suggestions...
i need help please!!!!!
tranny? does it make any other sounds other than idle and shaking noise? what happens when you are driving? any other info might help you get an answer...Lois: Oh, I haven't been on a college campus in years. Everything seems so different.
Stewie: Really? Perhaps if you laid on your back with your ankles behind your ears that would ring a few bells.
it does shift a little hard when i drive.. but they shaking is only when im stopped or when i get in my car in the mornings and but it into gear..but then it all the shaking stops when i drive for about 15 or 20 minutes..still shifts hard all the time though..just got my tranny flushed a few weeks ago though..
Well changing out trans fluiid is a good start. Check your rear mount?
Originally posted by 93hondaaccordexwhen i put my car in gear everything shakes and my idle goes way down like the car is going to die..i checked all my motor mounts and they look fine..the wierd thing is once i drive the car for about 15 minutes or so the shaking goes away please help with any suggestions...
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
i was thinking the same thing. sounds more or less electrical to me. have you checked grounds and ignition.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
Originally posted by kaponeyour describing an idle problem not a transmision problem .... its idleing rughf when the car is cold ... what maintanence have you done to the car lately ...?
i just replaced my axle, got a tranny flush and an alignment, oil change and thats about it.. i havent replaced my spark plugs for a little while could that be it?? and just to let you know i do let my car warm up before i take off for about 5 minutes or so but i still have this problem.. still an idleing problem??
i left a post the other day to what sounds like a similar problem of yours. check out what i had to say and see if that will help.
http://www.cb7tuner.com/vbb/showthre...0&page=2&pp=2091 Ex CB9
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
