Did the DIY IAC Valve Clean and now
    when the car is at full operating temp and I come to a complete stop the car nearly dies but slowly comes up to 950 rpms (high, I know). My concern is that the car ALMOST dies and goes down to roughly 500 rpms.
    Yes I did the ECU reset.
    Thoughts?
    After 17 years and 208K miles, I'm not "tuning" my CB7, I'm "restoring" a CLASSIC.
    mine did that, after a while it went away, my guess is that the ecu is relearning all the sensor info or something like that
    Members Ride
      Drive around for a while. The cleaning IAC is just a 50/50 fix. It can be just a dirty screen or the whole unit needs to be replaced.
        i did my IAC valve cleaning and when i rev it almost dies.. all i did was adjust the idle..
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          might need to adjust FITV
          ...adjust accordingly
            oky... i have done it about month ago.. but.. maybe you should
            you have to reprogram idle rpm level on the ECU...
            1.just make sure you let it cool down, unplug IAC valve connector (middle of intake manifolder)
            2.turn the engine on let it run until engine heats up( the fan should run at least onec or twice..)
            3.adjust the thottle body screw( i think you should adjust to 550rpm +50/-50 for f22 motor, and if you have h22a like mine should be 800rpm +50/-50)
            4. turn the engine off, plug the IAC valve connector
            5. unplug the 7.5amp "back up" fuse(mine was red) from the front fuse box under the hood on pass.side right near the right front suspension bushing
            6. wait for about 15sec plug it back on(reason for doing this BC you can reset,and reprogram your ECU with new idle rpm)
            7. start the car, let it heat up...
            DOne..
            mine works fine now...
            Pls do not stick Type-R or DOHC Vtec stickers
            if you do not have'm under the hood...
            that just makes you SUPER
            RRRRRRRRRRRicer....
