thok thok sound when car beggins to move back out
    I believe door pins make be shot, i hear this thok thok sound, could it be my door pins making this kind of sound when getting out of drive way.
    When door opens and closes, it make squeaching sound, ticking sound.
    Could door pins cause sounds, like thok thok.....I hear something around there, when moving in reverse from driveway ? like the body of car shifts ? there's some play ?
    what is this sound ?
      If your hearing it while you move then its something else. If its only when you open and cloes your door then you might need to grease up the hinges a bit. Your door feel loose and stuff? Like you can move it up and down and such?
        right on nail, so you're are saying, when the car starts to go in motion, there's no way that a door and its pins will move to cause cracking/thok sound a couple a times ? to think about it, it;s like a cracking sound ?
          Maybe if the hinge is worn out but I wouldnt think a door would shift when your in motion but I could be wrong. If you open the door its understandable. Sometimes when I open my door i get a slight crack thats because I know I need to grease up my hinges and crap but dunno if that is similar to your problem. Mine doesnt happen when I am in motion. If it is with the door I would see if someone from outside can hear it.
