automatic tranmission problem
    every time i shift the engine jerks. this only happens when you put the shift lever to drive or reverse. is there something wrong with my engine mount or cable. tnks in advance
    Rocky
    1993 LX 2DR Coupe bone stock 120,000 2nd owner
    1972 Celica 18RG project car
    1974 Celica Rust Free non running
    Engine mounts. Check em.
      or drain and refill ATF with "HONDA ATF"
        ok ill check the mounts btw how do you know if the mounts need to be replace?? i guess ill drain and refill the trany fluid with honda ATF.
          its nice to get your questions can answered immediately after posting...
          im still waiting ?
            One way to check easily is to put the car in park and don't have the e-brake on. Open the hood and grab the front of the car and pull and push it. This will show you how the engine mounts hold the engine. A little bit of play is normal but you'd notice if it had alot of play just by doing this.
            My '86 accord had this problem except that it was actually the engine that was broken. One of the mounting holes had actually sheered of a piece of the block. I didn't know this until that little peice flew up and snapped my timing belt and BLAMMO... pooched engine.
            ~Mike
              The mounts in the front and side are easy to check see if its cracking and stuff. Another way is to put load on the motor this require the e brake and putting it in first in reverse. Give it some gas in both gears and see how far the motor moves. Motor movement should be minimal. Or you can take a pry bar and try to shift the motor with it which is ghetto but works.
                most likely the front "dogbone" motor mount. In the front of the engine in the middle. You can use a light and look at the top of the mount and see if the rubber is split.
                1993 Honda Accord LX-auto--bone stock for now.--248K
                1997 Honda CRV--auto--bone stock--wife won't let me touch the CRV. 150K
                Need any performance parts? Check out my website or email me for prices.
                www.CARMandP.com
                Working on my H23 sway for free
                  i'd juat replace them for the hell of it. the cars old so it's going to have some issues.
                  i'm not saying it's one of those spur of the moment type things to do because i've never replaced engine mounts on anything i've driven before so i can't really say how long it would take.
                    my car does it and so does the other cb7 I drove today, its gotta be the rear mount cause my fronts new
                    My Members Ride Page
                      how many mounts that the engine and trany have??
                        3 engine, 1 trans.
