i was wondering if anyone has changed gears(to accomplish different gear ratios) in any of these cars? i have a h23 and a f22a6 transmission. i would like the shorter first 3-4 gears but a decent highway car. i took the h23 trans out cuz 3rd gear was grinding. wanted to rebuild it anyway.the f22 is ok but i really miss that strong pull with the h23 transmission.
changing gears in transmission
Check out gearspeed they have some stuff. ATS also if I remember.
The stronger pull you get with the H23 trans is largely due to the 4.266:1 final, as opposed to 4.0:1 with the F22 trans. If you want your first 4 gears to feel like the H23 box and 5th like the F22, then you should just take an H23 trans and have a custom 5th gear made that's a real deep overdrive to counteract the final drive ratio.
