My freakin turn signals
    Im trying to figure out why my turn signals keep going in and out, one day ill be ridin then the turn signals will come on for a couple of days then they just go out again all of a sudden. Does anybody have an idea of whats wrong???
    *****FOR SALE*****$2500
    A grounding issue of some sort maybe? Check the grounds to see if they are corroded or loose.
    Sean-Dinner.com
      bad signal control switch...u no the thing at the steering colum maybe that...loose connection?
        check to make sure the plug is properly seated on the switch. If yeah then try swapping it. Wires get corroded in honda all the time too. I had to rewire all my integra bumper lights.
        89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
        94 Honda Accord 2.2 EX (Daily For Now)
        04 Chevy Suburban 5.3 LT (Kiddie Haulin Pimpness)
          Have you checked any of the fuses
          Soon to be "The Beast"
            ive checked all of the fuses, but i have been having grounding issues, i think ima look in to that next...thanks alot
              Fuses wouldnt do that it just wouldnt work if it was blown out. CHeck your grounds as mentioned if you had those issues. Any previous work done to it before this happened?
                well it started right after i replaced my battery, my ground wire was messin up, sometimes my car wouldnt start unless id wiggle that ground wire.
