New (to me) 92 accord coupe EX questions..
    Hi all... this is my first honda, I bought it for the gas mileage and it seems like a very nice little car. It's a 92 ex coupe with 164k miles on it. I have a couple questions i'd like to ask you guys "the pros" about this thing.
    First, how hard is the timing belt to change? the guy said he hadn't changed it and didn't know if the guy before him had or not. I am fairly good mechanically.. rebuit engines etc.... and my dad has changed more than a few timing belts on his cars... is this do-able?
    Second, My only problem with it thus far is that it upon startup... sometimes it'll start right up, and sometimes it takes maybe 20 to 30 seconds of cranking to get it to start up... like a weak fuel pump or something like that... going down the road if I just stay in the gas enough to keep it up to speed it feels like it kind of surges a bit... which is why I think maybe a fuel filter....
    anyway... if there's any other nuggets of wisdom you guys can offer a new honda owner I'd appreciate it...
    Thanks and I look forward to reading/contributing for a long while here.. I've really enjoyed my first few days with the car... this being the first car I've owned... hopefully this thing will last me awhile...
    Here is the TIMING BELT procedure, and some other good links to start ya off.
    http://www.cb7tuner.com/vbb/showthre...ht=timing+belt
      Well we would love to see some pics of the car if you get a chance. Im curious as to what the differences are between the EX Coupe and the DX Coupe, because me and some friends saw huge difference between the DX Coupe and the LX Sedan other than the amount and size of doors.
      o and enjoy the car a lot, there great little cars, and i personally love the coupes
        I have the same starting problem thing as you...sometimes it wouldn't start at all no matter how much i cranked it...i thought i might have been out of gas, so i rocked the car and then it started like 10 seconds later.
        So i'm thinking it's also the fuel filter as well.
        Probably a good idea to change that thing as they often are neglected...i'm gonna need the flow anyways with the stock fuel pump and a turbo going on.
        Only other thing it could be is an intermitent fuel pump, and i've also heard such things as faulty main fuel pump relays. I donno.
        Good luck.
        mark
          Originally posted by mtnickel
          ... so i rocked the car and then it started like 10 seconds later.
          mark
          it probably is the fuel filter but b/c you said you rocked the car and then it strarted right up....i'm thinking that its a posibility that the sock on the fuelpump intake is clogged with junk and that when you rocked the car you knocked that stuff loose letting fuel get to the engine
          R.I.P. 6-10-07
          (\__/)
          (O.o )
          My Rotor DIY
          I'm not perfect i will make mistakes if i do just point it out to me
