have no heat, panel slider will move to heat position ? nothing..?
    92 honda accord lx, NO heat when the slider is moved to heat position.
    I can however, see in the engine compartment that, the wire needed to move from position cold or hot. Do i just slide the wire in or out to make cold or hot ?
    on my lx, i had the same thing, turns out the cable that controls the heat or cold, it came off the little pin the in the back, i took everything out, put it back on and heat works fine, while ur back there spray some wd 40 or something of that sort to ease the movement of the cable
    edit this is my 1000 post yay
    Members Ride
      Chances are the heater control valve cable is off and/or stuck. Replace the heater control valve if you can't switch to hot/cold if the cable is still attached.
      wat
        would this heater control valve possibly be located underneath the fuel filter??
        .............................-----------------93 Ex Coupe[/COLOR]-----------------
        My CD7
          yes, with a heater hose coming out it, that is the one
          Members Ride
            This is the tube that broke from my car. Well it didnt break but the fucking hose is so old, its leaking like crazy. Im getting a new one tommrow so that should be good w00t. Then I should have no leaks and my car wont overheat. Then I have to worry about the damn Oil pan since that shits all rusted and is leaking. and i know it's not the gasket. Eh oh well. it's funny to see peoples faces and tell me my car smoking, I just tell them thanks and go on my way ahahhaa
              Maple, don't you have the oil pan from your old motor?
              Gary A.K.A. Carter
              [sig killed by photobucket]
                what needs to be fixed to get slider planel for hot/cold to work ? with wire cable to valve to switch temp.
                dash have to come apart ?
                any how to's or
                diy for heater unit in dash ?
