Clutch Pedal Help!
    Clutch Pedal Help!
    real quick i got a new master slave cylinder. and the slave cylinder is working and everything. i was told my master cylinder was no good. i got a new one right now. and i install everything without reading the instruction. i took out the cover and strap and everything and installed it. i read it later and realize i wasnt suppose to take out blah blah blah well fuk the manual. so yeah now i'm fucked. i learn . but i dun understand the dam manual no pictures!! can sum1 give me the easiest way to explain wut i'm doing wrong? i'm not buildin any pressure. i noticed there's a screw on the side of the master cylinder am i suppose to open it so the brake fluid can run down or what? i pump it with my hands and hold it down and open the slave cylinder but still i'm not getting pressure it keep going to the floor.
    DEFJAM
    MY RIDE ON CB7 DEFJAM on 93
    bump!
    DEFJAM
      idk how to change one of those because i've never done one before, i'd just run back up to the auto parts store and grab one of those Haynes books. i'm sure they have plenty of pics to follow.
      or you could just wait till someone who has changed one to respond.
        yo everybody who read this. my bad seriously. i use the search forum and for the first time it helps alot!!! forget my thread
        DEFJAM
          remember the search button is ur friend
          glad u saw the light
          Members Ride
