Changing front brake
    I got a new set of Brembo slotted disc (don't know if it's the right word in english) and a set of ceramic pad for 200$... Now I don't want to go to a shop to do that... some of my friend told me it's was easy but can't help me so....
    I've search but i found nothing here to how changing the front disc...
    help me please :P
    http://www.cb7tuner.com/vbb/showthread.php?t=50708
    There's the DIY link. I personally had a shop do them. It took 4 hours for 2 guys to do my front brakes.
    1991 Cb7 Coupe 5 Speed--SOLD
    2002 Nissan Sentra SE-R Spec V-- SOLD
    1994 Acura Legend GS
    Car Pics
      get a Haynes manual from your local auto shop and it will only take 15-30min for each side, its really easy, you might have to go buy a couple cheap tools but it takes no time and is lot cheaper than going to a shop.
        Getting the rotors (discs) off is difficult. It's easiest to have them pressed off by a shop. You can remove the entire knuckle holding them, and have a shop do that (it'll be cheaper that way). I've seen people do it themselves, but I wouldn't try it myself. Converting to a rotor-over-hub setup is the best solution.
          What do you mean by that ??? (pic) :P
            i just change mine and it was a piece of cake.take the axle out and knuckle so u can swing the disc forward. take out all the bolt holdin the brake. remember where these bolts goes. behind it u'll find 4 12 point 10mm there... loosen em up but dont take em off.. bring it out about.. 3/4.. then take a hammer becareful not to strip them. just bang it normally like u'll see the disc starting to come off.. when all the 4 screw at touchin the metal. hold the disc and take out the screw. and u have the disc out. i replace em in 30 mins both sides.
            edit** i know that it sound soooooooo simple.. but takin out the axle is gonna be a pain in the ass. but doing it my way it came out very easily.. u need a breaker bar and a 36mm socket. if u have a automatic put the car in park. if u got a manual pull the handbrake.. enter the 36mm socket with the breaker bar attach to it. and with a hammer . hit the handle on the breaker bar really hard. i mean ur hardest. bout 15 hits u should have it off depending if your muscle or your a ... u know what..
            DEFJAM
            MY RIDE ON CB7 DEFJAM on 93
