powerless
    powerless
    I've been wanting to modify my accord without swapping in an h22. what kind of mods are available for my f22?? I dont have the money for turbos or superchargers if they do make one. I've heard of gude performance head packages but what can I do to the bottom for power
    Gude head packages are like 500 or so arent they. You could piece up a turbo kit if you save up a bit more. But if you want anything powerwise that would be the easiest route. If you want to go all motor on the other hand you might want to check out Hondafan81's white and red projects.
      you can do a cheap turbo kit from an old DSM eclipse/talon....
      the manifold just has to be redrilled to fit out block.
      the turbo bolts onto the manifold, you'd need a custom downpipe i believe.
      you'd need custom intercooler piping and an intercooler.
      the blue top injectors 450 CC i belive need little modification to fit in.
      a chipped ECU and a decent tune will have you up and running, and thats cheap
      think 500-1000 for that maybe
        gude head packages are like $1600. I dont wanna go turbo. just wanna keep it clean. pistons, head??? ecu?
          It can still be clean and be turboed so I am not seeing how that is a reason not to turbo...that is unless you were purposely looking for a reason. As was mentioned above, your cheapest route for power, which I am assuming is what you are looking for, is a DSM turbo setup. They are constantly popping up on the boards for sale. At one point I think there was one for like $600 with pretty much everything you needed. You can spend money on the n/a route but it will not give you the same power figures as F/I.
          Now on the other hand if you want to go N/A, the potential is there but it can also potentially cost you since power is addicting. Hondafan has 2 N/A projects so you might want to check those out for ideas of that nature.
          "This is a jaded bunch. To gain notice, you have to challenge conventional wisdom, test assumptions, and ignore the naysayers."
          FS Part out thread koni/skunk2 suspension, jdm pole, HID retrofit, Tanabe exhaust
            Thanx man. you're right i dont want to go turbo. I will check out hondafan.
            thanx again!! NICE CAR BY THE WAY
              horsepower = money + knowledge + connections.
                Just go to your local engine rebuilders and get them to rebuild your motor to OEM spec...you'll be surprised how much power your engine was missing. Plus is will be that much smoother and that much quieter.
                just a thought. All this will cost you around 700CAD or 500USD...of course depending on where u live.
                peace
                DEVOTE
                FS: Lokuputha's Stuff
                  If you go turbo you will also need a chipped p06 so you can tune it.
                    Can you be more descriptive on your goal? It doesn't help when you say you want to mod your car and make more power... I can say nitrous, turbo, s/c, NA...
                      no nitrous.wanna go head, cam, ecu, no turbo, who makes a good piston for it, higher compression. who makes a cam for it? Thanx for the input
