clutch problems
    clutch problems
    i have a 92 accord and i noticed a cricket sound when i wasnt on the clutch and it was gone when i was on the clutch. i knew my cylinders were bad so i replased them both primary and secondary cylenders, that fixed the skweeky ticking sound....but now my clutch is stuck to the floor!!!!! i cant even put it in gear!?!?! wtf?? i tried bleeding them but no good... anybody know what the problem could b?
    Apexi|HKS|Cusco|Eibach|Bilstien|Momo|
    92 ex-T sold
    94 z28 M6 sold
    89 turbo targa white package supra sold
    92 SW20 MR2 sold
    03 Impreza WRX
    when u bled the clutch did u do it the way a service manual says to do it or did u do it like a break bleed. search bleed clutch
      mine does the same thing, i even had to float the gears on the way home once! i blead the clutch, it went back to normal for a little while then did it again. like he said, you might be doing it the service manual way. i just keep the fluid level up now, i think it might be a leak in a line somewhere
      My Myspace
      91 accord lx 4 door 5 speed (a.k.a grasshopper)
      Mods:
      -Short Ram intake
      -92 accord EX intake manifold & exhaust
      -Ebay coilovers
      -BMW M3 style mirrors
      -OBXr Evo style exhaust
      -Multi-Colored Paint Job
      -cheap-o rims
      im goin to UTI June 17 2007
        Yeah mine used to do that but I took it to the shop for them to fix it then it was fine for a while. Then the slave cylinder was leaking, so I replaced that then I noticed the master cylinder was leaking, so I replaced that one also since I already had the parts because I knew it was going bad. now the clutch is to the floor.....I been trying to bleed the system but still nothing....its sucking up the fluid but still no pressure at all?!?!?!
        92 ex-T sold
        94 z28 M6 sold
        92 SW20 MR2 sold
        03 Impreza WRX
          whooo hooo!! i fixed my clutch problem just got back in. the damn clutch fluid line was loos and then i had to bleed the hole system. now i dont have to walk 2 school 2morow! lol or back home!
          92 ex-T sold
          94 z28 M6 sold
          92 SW20 MR2 sold
          03 Impreza WRX
            oh and thank s 2 evearybody for there help
            92 ex-T sold
            94 z28 M6 sold
            92 SW20 MR2 sold
            03 Impreza WRX
              eh.. not workin for me. i tighten everrrryytthinnggg... you could say i OVERTIGHTEN everything to make sure no leak. no luck. can i put some silicone on those screw to be 100% solid that i aint leakin? people say i might have a leak on the clutch line oka. i BEND the clutch line but understand what i mean by bend.. cuz i had to move it around sumthing i just put a small amount of pressure to install the clutch line but the brake fluid will flow. it's not bend like closing ur arm. i hold on the slave cylinder and i feel pressure. but when i let go i can see the slave cylinder opening. and i can still sqeeze it close. this normal ? i really wish someone here. the master cylinder is brand new
              DEFJAM
              MY RIDE ON CB7 DEFJAM on 93
                i had a similar prob with my second cb. it had just recieved a clutch replacement right before i bought it, and that glued to the floor shite started happening. the funny part was my boss at the ford dealership (i was a cashier in service dep.) saved the day by telling me to park it on a steep incline and pump the clutch peddle a bunch (while the car was running) and then hold it down. the air bubbles came out and there was no need to bleed the system. ta da. damn i was freakin out when that was all happening (traded 100$ and my first 90ex sedan for 90ex sedan standard trans.) and it had eighteens and was running like a champ. oh well that was three cars ago. glad you figured out the prob man.
                hey. my cb7 has morphed. haha.
