cb7 h22a AT missing low end TQ wat are my options..?
    cb7 w/h22a AT that i have... i m very happy when i m driving high speed but i m still missing low end HP/TQ of vq30dek engines,
    what can i do to boost low end..?
    i found about TQ converter for h22a, is it going to help..? how about under pully..?
    let me know guys
    thank you thank you
    Pls do not stick Type-R or DOHC Vtec stickers
    if you do not have'm under the hood...
    that just makes you SUPER
    RRRRRRRRRRRicer....
    You have an automatic. That means you already have a torque converter. It's not something that bumps power... just part of the transmission setup.
    An underdrive pulley won't make that much of a difference.
    You have an H22A. It's a high-revving Honda performance motor. The motor's strength lies in the top end. You'll NEVER get the low end grunt of a Nissan V6. The only option you really have would be to do some major internal work and increase the displacement as much as possible... or add a supercharger. Unfortunately, both options are pretty expensive (no current supercharger kit for the H22 will fit in the CB7 engine bay... the Procharger is the only one that might work, and nobody has done it yet... yet... I plan on it!)
    Get a timing light and retard your timing a bit. That will give you a little more low end...
    Get a smaller exhaust diameter (2.25" or less...) You'll lose performance, but you'll have more low end. Wider piping brings more power, but it moves the powerband up a bit as well.
    Get a smaller (or stock) intake setup.
    Get a P28 ECU and have it professionally tuned with your goals in mind.
      procharger..?
      you mean that intake with blowing motor infont so engine gets more airs..?
      and what about ITBs..?
      i know they are expensive but they really boost the low end..?
      how much gain can i expect w/h22a..?
      BC some times i can finds custom ITBs for hondas for about 400usd..
      RRRRRRRRRRRicer....
        Then you have to tune like crazy for them. And there is always the problem with no vacuum.
        Gary A.K.A. Carter
        [sig killed by photobucket]
          if you want low end power put your f22a back in
          h22's have vtec, vtec is made for power, in high rpms, thus rev happy.
