jdm vs usdm fuel rail
    this is for a post i read on the h swap as far as using my stock f22a6 rail and placing it on my jdm h22a to avoid changing fuel line from filter housing to rail as the main feed . what are your comments on this? is the f series rail smaller than h? i will be spraying as well so if it's smaller it's important i know. and yes fuel system is upgraded(walbro pump, larger lines from tank forward, aeromotive regulator) thank you
    My other ride is your ex-wife
    Same size. In fact, the JDM rail will have the output on the other side, making the F series rail the one most people use.
    You should read the H22 swap FAQ.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      every one says that but damn it's so long and i'm lazy most of the time.
        Yeah well I have read it, and I don't even have a H22. Or even swapped before.
        Gary A.K.A. Carter
          Same as long as you change over the injectors as mentioned. I am runnig my F series fuel rail on my car. YOu can use a 5th gen lude rail if you want also but the accord one will work just fine.
            accord rail with lude injectors right? since they are bigger and flow more fuel
