this is for a post i read on the h swap as far as using my stock f22a6 rail and placing it on my jdm h22a to avoid changing fuel line from filter housing to rail as the main feed . what are your comments on this? is the f series rail smaller than h? i will be spraying as well so if it's smaller it's important i know. and yes fuel system is upgraded(walbro pump, larger lines from tank forward, aeromotive regulator) thank you
jdm vs usdm fuel rail
Same as long as you change over the injectors as mentioned. I am runnig my F series fuel rail on my car. YOu can use a 5th gen lude rail if you want also but the accord one will work just fine.
