Expensive hit and miss experiance
    Ok well to start things off,
    I have a 1991 EXR 2 dr, when i first bought the car it burned oil and when cold smoked like a burning house, the minute the temps came up to normal operating temperature the smoke would stop, aside from the classic honda 7000rpm shift puff, so as time went on i decided that i needed to fix that polutionous problem, so my father and i thought we had it narrowed down to the cylinder head... which we then went ahead and swapped for one with less k's and pressure tested to be ok, needless to say it still smokes like crazy when its cold and stops when it warms up... weird... but now that the head is complete and swapped, all vac lines correct, timed properly, it seems to bog sporaticly, expecially noticable shifting into second gear, we have gone over several differant things and cant seem to find why its bogging and why its still smoking....
    does anyone have any input or possible ideas as to why it bogs and or why it smokes?
    any help would be greatly appreciated.
    Lightly Modded 91 EXR
    Exaust/Intake.
    Indash DVD, JBL Power series speakers all around, 2 rockford amps, 2 rockford subs, fully dynamated.
    Check your piston rings for wear? Do a compression test?
      compression test is well withing honda service manual and haynes manual specs.
      Exaust/Intake.
        Check your valve seals in the head or whatever there called.
          the head was pressure tested at 70psi, no problems with any seals...
          im not so much worried about the smoking as i am the bogging.
          Exaust/Intake.
            Is the head for the same engine? I.E. Is the new head off an engine with the same block #? Because some heads had different camshaft profiles.
            The valve guide seals could still be shot even if it it pressure tested ok. They are pretty cheap anyway, a bit of a pain to fit, but worth trying.
            My 5.7 LS1 Holden Ute
