Ecu question
    Ecu question
    Ok i aint new, but i am going to turbo my car at somepoint in time, now that i got a kit it is coming along faster. I was wondering i know about all the injectors n stuff, but what about ecu.
    With the new turbo setup installed what do i use for an ecu.
    from asking around at school i was told i could tune my stock ecu with safc 2 and a aem wideband o2 sensor, i am completly new to this, but i will be able to change and adjust things for temp and such here(gets snowy and very hot)
    if i buy a ecu online, i can get one pre programed for my turbo setup correct? what do i do when i wanna turn up the boost, get a new ecu, and or tune that one with above stuff?
    what is the best route, id like to stay cheap, i dont wanna dump a crap load into this seeing i already have a project car, and i need the honda to stay as my dd or at least till i fix my cuda so i can park my cb7 for a while.
    sugestions, comments. thanks guys
    My Ride17.34 @ 78mph with 260k on her
    alotta people do chipped p06....you can talkk to mrx aobut them he sells them
    My Members Ride Thread
      Do it right save you the hassle and go with a chipped p06. Its almost like a standalone.
        Best option is to use a PO6 Ecu out of 92-95 civic, and tune it using uberdata.
        Or you Could buy one of MRX's which are already chipped and have a basemap on them.
        My 5.7 LS1 Holden Ute
          so if i bought his ecu p06 then all i gotta do is plug in a go, and not worry about anything...sweet
            Yea and if you want to mod your map just pull out the chip and reburn a new map on there.
              well is just a basemap, you will have to mess with the the settings so will get the best performance out of it
              Members Ride
                so does that mean id have to buy a safc2 and o2 wideband to tune it if i want the best performance
                http://www.honda-tech.com/zerothread?id=98092 also i found that link i dont really get it, i could install example mrx's ecu and 450 injectors drive around like normal, then when i wanna boost the ecu would pick up that added air is being put into the engine and add fuel accordingly?
                  NO. you need to tune it. it will come with a BASEMAP, which is just enough to get you started. DO NOT DRIVE EVERYDAY ON A BASEMAP.
                  you have 2 options to tune the car.
                  1. Bring it to a dyno
                  2. buy a wideband 02 sensor, and street tune it yourself
                  and yes you can run the ECU before turbo, but honestly, it will probably run pretty shitty, especially up top.
                  i cant stress enough how important tuning is...you WILL end up with a blown motor if you dont take it very serious
                    alright thanks r33 youve been alot of help, thanks for clearing up some questions of mine
                    What is the point of buying a chiped ecu as apposted to tuning my stock ecu, is it just to prevent me from burning my engine up when i start it up for the first time, unless i am completly off in which i cant tune the stock honda ecu. cause if i am correct or wrong, the ecu would be just another 150 spend and then id still buy safc2 and o2 wideband and just tune it more.
                    i was also reading for my xs turbo on honda-tech people run them for a long time but the trick is to get a oil restrictor to not blow out the seals in the turbo, just though id update my new learing haha
                      Dont use the SAFC2...A chipped ECU works 10x better. The pT3/PT6 is not "tuneable" and especially if your gonna run boost. Buy a Wideband o2 for street tune or dyno tune. Find someone that can chip if you dont understand the program.
                        The Stock accord ecu cant be chipped. Tuning is the one thing you dont want to try and cheap out on.
                        Safc units have been used and worked, but are no way near as good as uberdata, Safc will add fuel but not change your timing.
                          Damn NAiL05 you beat me to it, well said though anyway
                            so i should just buy a pre tuned ecu from like mrx, with uberdata on it, drive it to a shop and have them tune it, i would rather tune it myself to save, what if i get uberdata and a safc 2? I know people who do know how to use this(safc2) if that helps.
                            get p06 ecu with uberdata, take it to local dyno shop, have them tune it, sounds like its gonna cost me an arm and a leg
                              Yeah tuning a honda for a turbo is somewhat involved. These guys are right a P06 will work well for an accord a p28 or p30 will work good to. The last two are usaully more expensive though because they have the vtec feature.
                              But a p06 can be converted to a p28 vtec ecu easily for say if you ever do an h22 swap or the h22 head frankenstien g22 thing. the p06 and the p28 are really the same computer the p06 just lacks the components needed for vtec.
                              for tuning. a chipped ecu and tuning your own fuel and ignition maps is the best way to go. Becuase you have control over you timing, to far advanced timing is what causes detonation and detonation causes engine failure like a melted piston cracked ringlands and sometimes just the whole top of the piston explodes!
                              Some people just use the safc to adjust for larger injectors and to add, that can actually work for some low boost setups but anything over like 6 psi and your timing will be so far advanced that you'll run into problems.
                              If you plan on running anything over ten or eleven psi you'll need a new map sensor like the motorola 2.5 bar. it reads up to twentyone psi and is way more reliable and easier to tune with then a GM map sensor. The Gm sensors are glitchy and inconsistant making tuning hard.
                              For tuning software I'd suggest using Crome Pro you can find it at Tunewithcrome.com
                              for more info on tuning check out homemadeturbo.com look in the engine managment forum
                              and pgmfi.org. Has pretty much all the information you need to know for tuning and chipping ecu's the seach function in there isn't very good though it seems like you can only do one search an hour the rest of your seaches come back with the same results..But the info in there is so good it's worth digging for.
                              and check out xenocron.com
