Larger Spark Plug Wires
    I'm going to get new plug wire soon. Is there a noticable difference in these aftermarket wires??? I'm thinking of some 10.2mm with those grounding straps on 'em ... is it worth it...
    Also, anyone notice a diff. with special plugs?? Like those iridium or platinums... I was told just get regular NGKs..
    Thanks
    ~Mike
    in my opinion i say stick with ngk when it comes to plugs and wires....As for whether you feel a difference ...it depends...whens the last time u changed your plugs and wires...if your old ones are in really bad condition the car should run a lil smoother...dont expect crazy gains
    My Members Ride Thread
      hope this help....but i change my stock ngks to ngk iridium cause my oem's were allready fuckt...and yes i notice a diffrence but not to crazy just minor...like how it allways is when u do a tune up....i notice my throtle response and acceleration is a lil bit better...starts smoother and idels smoother....but for wires...i don't know...my oems are doing reall good for me
      Signature removed due to excessive size. Please read the rules before creating a new signature. - cp[mike]
        Yeah I'm gonna get new wires regardless... I just saw a deal on those ones with the ground straps and figured I'd check to see if anyone actually uses them first.
          Yeah I had a set of OBX plugs and 10.2 plug wires. They didn't make a difference when I put them on and I think they actually made the car run worse. I then learned my lesson and bought NGK plugs and wires. IMO they're the best brand to use for our cars. My car has been runnin smooth since.
          Never underestimate a 4-door Accord
            OEM PLUGS N WIRES!! lol or NGK blues......anything else isnt worth it on a stock F series engine.....IMO!
            F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
            Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
            Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
              every time i do a tune and replace the plugs, i always have to replace the wires too because i end up breaking one.
                any one of you can go and pick up the honda builders handbook at any bookstore and you will learn a lot about plug wires that may shock you,
                first yes new wires conduct more than old ones, most stock wires are carbon based which wear down over time
                second, no wire adds power, just gives you more spark via less resistance which gives you a hotter spark and burns your fuel durring lean conditions better
                third, these magical ground strap capasitor wires are a bunch of bull and actualy can mess with the electronic flow through the wire
                according to the people in the book, aka the people at jackson racing, megnacore wires, and so forth your best bet is not wasting your money on 50 inch thick wires but to get a solid non carbon core wire ( aka not stock replacements) and you will get all you can out of a stock ignition. if you get the book they explain it a lot better, there is a whole chapter on just ignition, ill post a pic of the cover latter
                PEACE
                New cb, new start
