Brake problems
    Brake problems
    My brakes are spongy and getting worse. I'm not losing any fluid so I know there's no leak in the lines. Could it be the master cylinder or something else I'm missing?
    Yep sounds like you solved your problem. If your pedal is starting to sink its your brake master cylinder. If it feels like there is air. I would rebleed and see if that helps. Sometimes if your brake pads are worn you will need to step down a lil further before the brakes actually "grab" So if you know the pads are good, and bleeding it doesnt help then it would be your MC thats the problem.
      if you press your brake and it stops half way and slowly sinnks down to the ground ,then your hose that runs from the intake to the brake booster is leaking, you need to replace that! But do check that hose that run from intake manifold to braker booster
        MS same problem here
          try pressing the brake pedal while the car is running. now turn the car off. if the pedal doesn't rise you'll have to replace the brake booster. if it does rise, you most likely have a leak in the hose running to the manifold. another tell tell sign is a wooshing sound from under the dash while the car is running. hope this helps some.
            nice instructions! wanna try that now
              I have brand new CERAMIC brake pads for sale, if you need them.
                i had the same problem,it's the master cylinder,get that replace.
                SAFETY FIRST
                -->751 whp @ 27psi <--...Midnight Tuning <----
                  My pedal feels fine it just sinks, and I found both rearl wheel cylinders leaking massively. So they will be being replaced
                    good luck,and be safe
