listen, im new to this forum, but friends told me to come on here and see what i could figure out. last weekend we did a swap out of my 95 accord ex. we put a 97 f22a1 in it and now vtec is not working, it was working with the old engine, but the engine was so tired that it had trouble reving up that high. now when u punch it it gets to about 5 grand and looses all power as if thats where the rev limiter is now. can anybody help me fix this problem. also i have the old f22a1 for sale. the head, intake manifold, throttle body, are all still in good condition, the block, needs to be rebuilt. will sell for cheap or trade for something.
vtec wont work need some help please
Originally posted by ciccotti69listen, im new to this forum, but friends told me to come on here and see what i could figure out. last weekend we did a swap out of my 95 accord ex. we put a 97 f22a1 in it and now vtec is not working, it was working with the old engine, but the engine was so tired that it had trouble reving up that high. now when u punch it it gets to about 5 grand and looses all power as if thats where the rev limiter is now. can anybody help me fix this problem. also i have the old f22a1 for sale. the head, intake manifold, throttle body, are all still in good condition, the block, needs to be rebuilt. will sell for cheap or trade for something.
Also they did not have a 97 f22a1.
If both engines were out of ex the code should be f22b1 on them (sohc vtec, comes in the ex chassis). Check the engine codes again because there is also the non-vtec f22b2 that comes out of the lx/dx models. Why did you end up swapping the engine harness? If they were both the f22b1 there should be no difference in harnesses...Retired 1990 Accord LX Coupe
Project 240SX
Originally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
Yep both were b1 it would be pointless to switch harnesses...And if you had to swap it out then you prob got the shit non vtec motor.
I Had To Switch The Harness Because Of Obd2 And Obd1. The 95 Is Obd1 And The 97 Is Obd2. There Is A Crank Sensor On The New Motor, And Not One On The Old. Engine Codes Are Exactly The Same Trust Me I Checked. And It Says Vtec Right On The Valve Cover. Wont Rev Past 5000 Rpm. There Is A Check Engine Light, But I Dont Have A Diognostis Reader. Nobody Has Experienced This Problem?? I Heard It Was Common
Should have kept it OBD1. Just use parts off the old 95 motor that you had. If your only revving till 5000 could be related to your VTEC. Hows oil levels and stuff on the car.
Originally posted by ciccotti69I Had To Switch The Harness Because Of Obd2 And Obd1. The 95 Is Obd1 And The 97 Is Obd2. There Is A Crank Sensor On The New Motor, And Not One On The Old. Engine Codes Are Exactly The Same Trust Me I Checked. And It Says Vtec Right On The Valve Cover. Wont Rev Past 5000 Rpm. There Is A Check Engine Light, But I Dont Have A Diognostis Reader. Nobody Has Experienced This Problem?? I Heard It Was CommonRetired 1990 Accord LX Coupe
Project 240SX
When he comes in saying he swapped in an F22A1 and VTEC is not working, how can we assume he knows what he's talking about? If he doesn't know what motor it is, why should he know how to rewire for OBD2? "thanks for no help" is uncalled for. The first thing to address is that it is indeed the proper motor. ALL we know is what is said in the original post. When we have F22A1 to work with, we assume he means F22A1.
Anyway, if you want to scan for codes, hit up Autozone. They'll do it for free. It seems to me that the car is in limp-mode for some reason. Probably a bad sensor or bad connection somewhere. I know I've done work on my car, only to find that it doesn't start because I forgot to plug in something minor... like the distributor
Once you scan for codes, you'll have a better idea as to what's wrong. Fix what the scanner says, and then we can take it from there.
If everything has been rewired for OBD2, you ARE using the OBD2 ECU, right?
it was a typo... his bad...but he didn't need the bandwagon of newbie jumpers to argue over the code... once the car gets put on the road he can scan it at autozone... but i'm pretty sure everythigns plugged in (as i worked on this swap) its gotta be a vtec code cuz other than that it runs great...
SOLD!
