Originally posted by g-wagon
vtec wont work need some help please
Originally posted by MadSpleen85Sounds like someone is losing their patience. Just as a suggestion I would take a picture of the motor just for reference to everyone. That may help a bit. Just my two cents worth. Sometimes you gotta have patience on here until you get someone that has been there and done that. Takes some time. Good Luck. Later
naw dude... its a f22b1... 100% postive... the one in my sig is the old motor of his... we drove it today and its pretty quick up till about 5 grand then it just kinda falls out...
SOLD!
Agreed. If it was a typo, nobody knew it when the offered advice. Keep that in mind. We only know what is given to us here... you worked on the swap, so what seems obvious to you isn't obvious to us.
If everything is plugged in, there's probably a bad sensor or solenoid somewhere. The scanner should pick that up right away.
Originally posted by deevergoteAgreed. If it was a typo, nobody knew it when the offered advice. Keep that in mind. We only know what is given to us here... you worked on the swap, so what seems obvious to you isn't obvious to us.
yeeep... we'll see... hopefully its pretty quick..
SOLD!
