Change Of Plans!!!
    Yeah, good advice
      Originally posted by 91f22a4philly
      i thought the f22 had a lower compression ratio then the h22 hence better suited for a turbo and a longer life less stress ? or is that not the case i mean i know they have kits to lower compression but i just thought it was easier to sart with lower compression just like if a car came turbo'd from factory it would be easier to add a diff turbo or intercooler etc...you know wut im still learning so any advice or knowledge i dont have will be fully embraced
      Yes, it'll have lower compression than an H, but what it doesn't have is the capability to handle much boost...... Many dsm and other budget turbo setups have been done on these motors. Some guys are still running them with MINIMAL boost, others have fried rings, broke off ringlands, had head gasket issues, etc. There's just not a ton of reliability/longevity boosting an F22, considering it wasn't designed for F/I to begin with. An N/A H22 setup is really the way to go unless you've got tons of money to blow.
      1992 Accord LX - SOLD
        THANKS! ill be gettin an h now i want reliable motor! an where could i find a kit to lower compression and the cost? thanks everyone for your help
        GOT SOMETHING SPECIAL FOR YALL .....STAY TUNED
          Ummm, well I'm not turboed but I think that a thicker head gasket is where you should start. My suggestion is to avoid boosting, but again that's just my opinion. Neither the f or h motors are much good for it, and from what I've read the h should be re-sleeved, and that's not cheap.
            F series engines are good for boost . after 8psi, you would need engine work.
