adjusting timing belt
    I know this a stupid question, but is there a easier way to adjust the timing belt without taking it off completly?I put the belt on but the cams are like one tooth from where they should be .or do you think that it would be ok and won't damage anything?
    why aint nobody respondin to this question? it'a a good question.
    DEFJAM
    MY RIDE ON CB7 DEFJAM on 93
      cuz no one knows the answer lol
      Not my fault my dick only fits magnums.
      Why drink and drive when you can smoke and FLY?
        no. if the belt is a tooth or more off, you should remove it, and redo it. your car will run like shit. however, you dont have to remove the motor mount to do this i dont think. at least on the integra i dont have to
        If you just need to adjust tension, you can do this without removing the belt.
          SEE i knew that would get someone to answer the damn thing, lol
            okay but wait... those cam are adjustable... so when u install it and ur like 1 tooth off.. why cant u just lift the belt up and spin the cam backward till it gets in the tooth. but in case that's impossible.. then uhh..does the bottom of the belt whereever it's connect to have teeth n the cam?? but yo.. if this thang dont gain no horsepower or barely. it's not worth it cuz if there's any mistake u fuk up the engine. take it off bro. sell it back on ebay.
            DEFJAM
              Yea thats what I did I had somebody hold the cam back and I slid the belt on
