What do you think the F22B DOHC is? Its a JDM STOCK frankenstein motor.
F22 bottom end, but with the capabilities of an H23.
so, if you put any of those heads onto an F22A block, its gona be exactly the same as the F22B.
anything can be as reliable as you want it to be. That goes with wild NA to wild turbo setups.
Logic tell you that a stock motor is as reliable as it could be. Once you put something aftermarket on it it is less reliable and the more stuff you put on it, the less reliable it is, etc, etc..... atleast thats what logic tells us. Logic is not always correct.
Maintainance(sp?) as well as parts used are key in reliability.
