I am having difficulty trying to figure out wether i should turbo my f20a that was prepped for a turbo and is prety much ready for it. OR should i take the motor out and drop a H22 in it?? If you say turbo do you know any sites i might be able to find it?? thanks
F20a Turbo?
If the motor is already built for turbo (meaning low-compression forged pistons, forged rods, and at the very least a fresh valvetrain), then I would say go turbo. No need to waste a built motor! Unless you don't want the extra hassles turbo brings (turbo IS a bit more maintenance-heavy than a healthy stock H22). In which case, you could probably find a buyer very quickly for the motor.
If you want to go turbo (which will make more power for less money than an H22 if done right) then you may have to build your own kit.
I'm not sure how the exhaust ports are on the F20A, so you may or may not be able to use an exhaust manifold from a Mitsubishi Eclipse (like they do on the F22A). A t3/T04 hybrid turbo is your best bet, though you could probably get by with a larger T3 turbo... Or, if you go the Mitsubishi route, the "big" 16G turbo from the Evo is an excellent choice (also on a 2.0L motor, so it's a decent match for displacement).
Search on the site for "DSM" turbo kits and you'll find all the information you need for building your own setup.
What has been done to this F20A? "Prepped for turbo" could mean anything from the lips of a shady seller. Be sure you KNOW exactly what has been done to this motor before you assume. Ask for receipts, if you don't know firsthand. What is inside that block makes a BIG difference on what you can do with it!
Thanks for all that.
Ive talked to the guy and he can tell me everythings he has done to it. So far hes told me alot about it and everything done to it. But Im kinda new to all this and i dont remember all that great of an amount of what he has done. So ill findout soon what exactly was added and how much more i need to have turbo put on it. Ive never heard anything about a mitsubishi head going on a f20a accord or anything. Im going to do some research and find out were i can get the turbo. thanks for everything.
