ok i picked up a 92 black 5 speed 10th anv. accord it has minor problems that can be fied in needs a new coat of paint,and the interior cleaned a bit lastly the owner said that his main reason for selling is that the balance pulley broke and that it need to be replaced i never heard about this part but inko that it's in the timing belt reigon of probs. i wanted to know if this is a quick fix is it repairable or do i have to buy a long block any info would be helpful. i just want to know will i be able to fix it.
Balnce pulley
Originally posted by 92BLACKEXWitch balance pulley? like the crank pulley? Cuz it is that then its easy, you can get the after market light weight ones for like $30 shipped. Plus you'll need to get different sized belts though, but you should replace those belts anyways.
I thought all the 10th aniv. Accords were automatic...
Anyway, it's not an easy fix if you're not comfortable with engine work. It probably won't be extremely cheap to fix at a shop. You might want to ask around, and then research some engine swap options... it may be cheaper to upgrade the motor.
As for those $30 crank pulleys, I wouldn't touch those with a stick. If you don't get something quality, such as Unorthodox Racing, you run the risk of getting something that isn't properly balanced. That could cause some major problems. Spend the money for quality with those.
Originally posted by deevergoteI thought all the 10th aniv. Accords were automatic...
so u ino wut im talkking about?????
